Uclan Denys H.265 EU
T2MI and MULTISTREAM support without input parameters & HARDWARE BLINDSCAN!
Denys H.265 EU — legendary model for European DVB/IPTV market already there! Same as Denys H.265, hidden features of the new Denys H.265 EU is in addition to T2MI and Multistream he’s dimensions. The device is only 12cm x 2.5cm x 8cm small! This special feature makes the Denys H.265 EU suitable for (wall) mounting behind a TV (external infrared receiver included) or in another hidden location.
In addition, the device is ideal for travel or camping use, because have 12volt power plug. The small, high performance is functionally as good as its big brothers, but designed for mobile or hidden use.
Of course you can still place it visibly. He is an eye-catcher anyway! With the Denys H.265 EU, viewers can take full advantage of the multimedial possibilities, such as Cinema portals, IPTV playlists in memory, IPTV autoupdate .m3u, Stalker middleware portals, XTREAM IPTV, YouTube, ***Tube, Internet Radio and many more.
H.265 DVB-S2 HD Multistream with a strong tuner and hardware blind search (blind scan) complete the product. As well as a card reader Conax, with OSCAM support!
Key Features:
- H.265 / MPEG4 — HD / SD, DVB-S2 Multistream Tuner
- Multistream Root, Gold, (PLP, PLS) T2MI support without parameter input
- Hardware BlindScan (Low-search) support with low symbol rates (Low Symbol Rate Support)
- IPTV in memory and external weblinks
- OTT
- Stalker portals support
- Xtream IPTV
- CE sertificates
- .m3u, YouTube, ***Tube
- 2 x USB 2.0 ports
- 4-digit 7-segment display
- E2 (Enigma2) Settings Support
- Channels picons support
- EPG in IPTV (related with channel name)
Characteristics:
- Linux OS operating system
- WebIF & FTP access
- Conax card reader with full OSCAM
- Recording & TimeShift (* optional)
- Network 10 / 100Mbit LAN
- WiFi (WiFi) + 3GB Model Support via USB ports
- DLNA Player Support
- Unicable & FastScan support
- DiSEqC 1.0, 1.1, 1.2 and USALS support
- EPG — Electronic Program Guide
- High resolution OSD UI user interface
- 4x programmable buttons on the remote control
- Subtitles & Teletext (Teletext) Support
- 0.5W standby
- Dimensions (LxDxH) 120mm x 80mm x 25mm
Front:
LED display (red / green)
IR sensor (infrared receiver)
Back:
H.265 HD DVB-S2 tuner LNB input
Network 10 / 100Mbit connection
HDMI output
Digital audio output
AV — Audio Video Jack — Jack to RCA
Sides:
LED / IR (external display or IR infrared receiver) connection
2 USB 2.0 port
USB 2.0 port
DC-12V power supply
RS232 socket
