188/204 codage reed solomon
Messagepar PY-74 » 10 Jan 2006 09:40
Puis-je profiter d'une explication ?
cétikoi ça , le codage solomon?
[url]un lien[/url]ou un petit dicours me suffirait .
merci d'avance[/url]
PY-74
Messagepar Laurent » 10 Jan 2006 09:47
Laurent
Messagepar babal45 » 16 Fév 2006 23:02
#!/usr/bin/perl # ===================================================================== # ---------------------- # DBMan # ---------------------- # Database Administrator # # File: db.cgi # Description: This is the main program file and contains all the functionality # of the database manager. # Author: Alex Krohn # Web: http://www.gossamer-threads.com/ # Version: 2.05 # CVS Revision: $Id: db.cgi,v 1.6 2000/07/08 18:14:40 alex Exp $ # # COPYRIGHT NOTICE: # # Copyright 1997 Gossamer Threads Inc. All Rights Reserved. # # This program is being distributed as shareware. It may be used and # modified free of charge for personal, academic, government or non-profit # use, so long as this copyright notice and the header above remain intact. # Any commercial use should be registered. Please also send me an email, # and let me know where you are using this script. By using this program # you agree to indemnify Gossamer Threads Inc. from any liability. # # Selling the code for this program without prior written consent is # expressly forbidden. Obtain permission before redistributing this # program over the Internet or in any other medium. In all cases # copyright and header must remain intact. # # Please check the README file for full details on registration. # ===================================================================== # If you run into problems, set $db_script_path to the full path # to your directory. $db_script_path = "."; # Load the form information and set the config file and userid. local(%in) = &parse_form; $in{'db'} ? ($db_setup = $in{'db'}) : ($db_setup = 'default2'); $in{'uid'} ? ($db_uid = $in{'uid'}): ($db_uid = ''); # Required Librariers # -------------------------------------------------------- # Make sure we are using perl 5.003, load the config file, and load the auth file. eval { unshift (@INC, $db_script_path); require 5.003; # We need at least Perl 5.003 unless ($db_setup =~ /^[A-Za-z0-9]+$/) { die "Invalid config file name: $db_setup"; } require "$db_setup.cfg"; # Database Definition File require "auth.pl"; # Authorization Routines }; if ($@) { &cgierr ("Error loading required libraries.\nCheck that they exist, permissions are set correctly and that they compile.\nReason: $@"); } # If we are using benchmarking, then we start a timer and stop it around &main. Then we print the difference. if ($db_benchmark) { eval { require Benchmark; }; if ($@) { &cgierr ("Fatal Error Benchmark Module not installed: $@"); } $t0 = new Benchmark; } eval { &main; }; # Trap any fatal errors so the program hopefully if ($@) { &cgierr("fatal error: $@"); } # never produces that nasty 500 server error page. # Stop the timer and print. if ($db_benchmark) { $t1 = new Benchmark; print "
Processing Time: " . timestr(timediff($t1, $t0)) . "
# "; } # Display debugging information if requested. &cgierr("Debug Information") if ($db_debug); exit; # There are only two exit calls in the script, here and in in &cgierr. sub main { # -------------------------------------------------------- my ($status, $uid); local($per_add, $per_view, $per_mod, $per_del, $per_admin); $|++; # Flush Output Right Away &auth_cleanup unless ($auth_no_authentication); # Remove old session files. ($status, $uid, $per_view, $per_add, $per_del, $per_mod, $per_admin) = &auth_check_password; # Authenticate User, get permissions and userid. if ($status eq "ok") { # Set the script link URL with db and user info for links. Use $db_script_url for forms. $db_script_link_url = "$db_script_url?db=$db_setup&uid=$db_uid"; if ($uid eq "default") { $db_userid = $uid; } else { ($db_userid) = $db_uid =~ /([A-Za-z0-9]+)\.\d+/; } # Main Menu. Check to see what the user requested, then, if he has permission for that # request, do it. Otherwise send the user off to an unauthorized request page. if ($in{'add_form'}) { if ($per_add) { &html_add_form; } else { &html_unauth; } } elsif ($in{'add_record'}) { if ($per_add) { &add_record; } else { &html_unauth; } } elsif ($in{'view_search'}) { if ($per_view) { &html_view_search; } else { &html_unauth; } } elsif ($in{'view_records'}) { if ($per_view) { &view_records; } else { &html_unauth; } } elsif ($in{'delete_search'}) { if ($per_del) { &html_delete_search; } else { &html_unauth; } } elsif ($in{'delete_form'}) { if ($per_del) { &html_delete_form; } else { &html_unauth; } } elsif ($in{'delete_records'}) { if ($per_del) { &delete_records; } else { &html_unauth; } } elsif ($in{'modify_search'}) { if ($per_mod) { &html_modify_search; } else { &html_unauth; } } elsif ($in{'modify_form'}) { if ($per_mod) { &html_modify_form; } else { &html_unauth; } } elsif ($in{'modify_form_record'}) { if ($per_mod) { &html_modify_form_record; } else { &html_unauth; } } elsif ($in{'modify_record'}) { if ($per_mod) { &modify_record; } else { &html_unauth; } } elsif ($in{'admin_display'}) { if ($per_admin) { &admin_display; } else { &html_unauth; } } elsif ($in{'logoff'}) { &auth_logging('logged off') if ($auth_logging); (-e "$auth_dir/$db_uid") and ($db_uid =~ /^[\A-Za-z0-9]+\.\d+$/) and unlink ("$auth_dir/$db_uid"); $auth_logoff ? (print "Location: $auth_logoff\n\n") : (print "Location: $db_script_url\n\n"); } elsif ((keys(%in) <= 2) || ($in{'login'})) { &html_home; } else { &html_unkown_action; } } # If we allow users to signup, and they want to, go to the signup form. elsif ($auth_signup and $in{'signup_form'}) { &html_signup_form; } elsif ($auth_signup and $in{'signup'}) { &signup; } # Auth Check Password has determined that the user has not logged in, so let's send # him to the login screen. elsif ($status eq "no login") { &html_login_form; } # Auth Check Password had an error trying to authenticate the user. Probably there was # an invalid user/password or the user file has expired. Let's go to an error page and # ask the user to re log on. else { &html_login_failure($status); } } sub add_record { # -------------------------------------------------------- # Adds a record to the database. First, validate_record is called # to make sure the record is ok to add. If it is, then the record is # encoded and added to the database and the user is sent to # html_add_success, otherwise the user is sent to html_add_failure with # an error message explaining why. The counter file is also updated to the # next number. my ($output, $status, $counter); # Set the userid to the logged in user. ($auth_user_field >= 0) and ($in{$db_cols[$auth_user_field]} = $db_userid); # First we validate the record to make sure the addition is ok. $status = &validate_record; # We keep checking for the next available key, or until we've tried 50 times # after which we give up. while ($status eq "duplicate key error" and $db_key_track) { return "duplicate key error" if ($counter++ > 50); $in{$db_key}++; $status = &validate_record; } if ($status eq "ok") { open (DB, ">>$db_file_name") or &cgierr("error in add_record. unable to open database: $db_file_name.\nReason: $!"); if ($db_use_flock) { flock(DB, 2) or &cgierr("unable to get exclusive lock on $db_file_name.\nReason: $!"); } print DB &join_encode(%in); close DB; # automatically removes file lock if ($db_key_track) { open (ID, ">$db_id_file_name") or &cgierr("error in get_defaults. unable to open id file: $db_id_file_name.\nReason: $!"); if ($db_use_flock) { flock(ID, 2) or &cgierr("unable to get exclusive lock on $db_id_file_name.\nReason: $!"); } print ID $in{$db_key}; # update counter. close ID; # automatically removes file lock } &auth_logging("added record: $in{$db_key}") if ($auth_logging); &html_add_success; } else { &html_add_failure($status); } } sub delete_records { # -------------------------------------------------------- # Deletes a single or multiple records. First the routine goes thrrough # the form input and makes sure there are some records to delete. It then goes # through the database deleting each entry and marking it deleted. If there # are any keys not deleted, an error message will be returned saying which keys # were not found and not deleted, otherwise the user will go to the success page. my ($key, %delete_list, $rec_to_delete, @lines, $line, @data, $errstr, $succstr, $output, $restricted); $rec_to_delete = 0; foreach $key (keys %in) { # Build a hash of keys to delete. if ($in{$key} eq "delete") { $delete_list{$key} = 1; $rec_to_delete = 1; } } if (!$rec_to_delete) { &html_delete_failure("no records specified."); return; } open (DB, "<$db_file_name") or &cgierr("error in delete_records. unable to open db file: $db_file_name.\nReason: $!"); if ($db_use_flock) { flock(DB, 1); } @lines = ; close DB; ($restricted = 1) if ($auth_modify_own and !$per_admin); LINE: foreach $line (@lines) { if ($line =~ /^$/) { next LINE; } if ($line =~ /^#/) { $output .= $line; next LINE; } chomp ($line); @data = &split_decode($line); ($output .= "$line\n" and next LINE) if ($restricted and ($db_userid ne $data[$auth_user_field])); $delete_list{$data[$db_key_pos]} ? # if this id is one we want to delete ($delete_list{$data[$db_key_pos]} = 0) : # then mark it deleted and don't print it to the new database. ($output .= $line . "\n"); # otherwise print it. } foreach $key (keys %delete_list) { $delete_list{$key} ? # Check to see if any items weren't deleted ($errstr .= "$key,") : # that should have been. ($succstr .= "$key,"); # For logging, we'll remember the one's we deleted. } chop($succstr); # Remove trailing delimeter chop($errstr); # Remove trailing delimeter open (DB, ">$db_file_name") or &cgierr("error in delete_records. unable to open db file: $db_file_name.\nReason: $!"); if ($db_use_flock) { flock(DB, 2) or &cgierr("unable to get exclusive lock on $db_file_name.\nReason: $!"); } print DB $output; close DB; # automatically removes file lock &auth_logging("deleted records: $succstr") if ($auth_logging); $errstr ? # Do we have an error? &html_delete_failure($errstr) : # If so, then let's report go to the failure page, &html_delete_success($succstr); # else, everything went fine. } sub modify_record { # -------------------------------------------------------- # This routine does the actual modification of a record. It expects # to find in %in a record that is already in the database, and will # rewrite the database with the new entry. First it checks to make # sure that the modified record is ok with validate record. # It then goes through the database looking for the right record to # modify, if found, it prints out the modified record, and returns # the user to a success page. Otherwise the user is returned to an error # page with a reason why. my ($status, $line, @lines, @data, $output, $found, $restricted); $status = &validate_record; # Check to make sure the modifications are ok! if ($status eq "ok") { open (DB, "<$db_file_name") or &cgierr("error in modify_records. unable to open db file: $db_file_name.\nReason: $!"); if ($db_use_flock) { flock(DB, 1); } @lines = ; # Slurp the database into @lines.. close DB; ($restricted = 1) if ($auth_modify_own and !$per_admin); $found = 0; # Make sure the record is in here! LINE: foreach $line (@lines) { if ($line =~ /^$/) { next LINE; } # Skip and Remove blank lines if ($line =~ /^#/) { $output .= $line; next LINE; } # Comment Line chomp ($line); @data = &split_decode($line); ($output .= "$line\n" and next LINE) if ($restricted and ($db_userid ne $data[$auth_user_field])); if ($data[$db_key_pos] eq $in{$db_key}) { # If we have userid's and this is not an admin, then we force the record to keep it's own # userid. if ($auth_user_field >= 0 and (!$per_admin or !$in{$db_cols[$auth_user_field]})) { $in{$db_cols[$auth_user_field]} = $data[$auth_user_field]; } $output .= &join_encode(%in); $found = 1; } else { $output .= $line . "\n"; # else print regular line. } } if ($found) { open (DB, ">$db_file_name") or &cgierr("error in modify_records. unable to open db file: $db_file_name.\nReason: $!"); if ($db_use_flock) { flock(DB, 2) or &cgierr("unable to get exclusive lock on $db_file_name.\nReason: $!"); } print DB $output; close DB; # automatically removes file lock &auth_logging("modified record: $in{$db_key}") if ($auth_logging); &html_modify_success; } else { &html_modify_failure("$in{$db_key} (can't find requested record)"); } } else { &html_modify_failure($status); # Validation Error } } sub view_records { # -------------------------------------------------------- # This is called when a user is searching the database for # viewing. All the work is done in query() and the routines just # checks to see if the search was successful or not and returns # the user to the appropriate page. my ($status, @hits) = &query("view"); if ($status eq "ok") { &html_view_success(@hits); } else { &html_view_failure($status); } } sub query { # -------------------------------------------------------- # First let's get a list of database fields we want to search on and # store it in @search_fields my ($i, $column, @search_fields, @search_gt_fields, @search_lt_fields, $maxhits, $numhits, $nh, $field, @regexp, $line, @values, $key_match, @hits, @sortedhits, $next_url, $next_hit, $prev_hit, $first, $last, $upper, $lower, $left, $right, $restricted); local (%sortby); # First thing we do is find out what we are searching for. We build a list of fields # we want to search on in @search_fields. if ($in{'keyword'}) { # If this is a keyword search, we are searching the same $i = 0; # thing in all fields. Make sure "match any" option is $in{'ma'} = "on"; # on, otherwise this will almost always fail. foreach $column (@db_cols) { if (($db_sort{$column} eq 'date') or &date_to_unix($in{'keyword'})) { $i++; next; } if ($i == $auth_user_field) { $i++; next; } push (@search_fields, $i); # Search every column $in{$column} = $in{'keyword'}; # Fill %in with keyword we are looking for. $i++; } } else { # Otherwise this is a regular search, and we only want records $i = 0; # that match everything the user specified for. foreach $column (@db_cols) { if ($in{$column} =~ /^\>(.+)$/) { ($db_sort{$column} eq 'date') and (&date_to_unix($1) or return "Invalid date format: '$1'"); push (@search_gt_fields, $i); $in{"$column-gt"} = $1; $i++; next; } if ($in{$column} =~ /^\<(.+)$/) { ($db_sort{$column} eq 'date') and (&date_to_unix($1) or return "Invalid date format: '$1'"); push (@search_lt_fields, $i); $in{"$column-lt"} = $1; $i++; next; } if ($in{$column} !~ /^\s*$/) { ($db_sort{$column} eq 'date') and (&date_to_unix($in{$column}) or return "Invalid date format: '$in{$column}'"); push(@search_fields, $i); $i++; next; } if ($in{"$column-gt"} !~ /^\s*$/) { ($db_sort{$column} eq 'date') and (&date_to_unix($in{"$column-gt"}) or return "Invalid date format: '$in{$column}'"); push(@search_gt_fields, $i); } if ($in{"$column-lt"} !~ /^\s*$/) { ($db_sort{$column} eq 'date') and (&date_to_unix($in{"$column-lt"}) or return "Invalid date format: '$in{$column}'"); push(@search_lt_fields, $i); } $i++; } } # If we don't have anything to search on, let's complain. if (!@search_fields and !@search_gt_fields and !@search_lt_fields) { return "Sie haben keine Kriterien ausgew�hlt!"; } # Define the maximum number of hits we will allow, and the next hit counter. $in{'mh'} ? ($maxhits = $in{'mh'}) : ($maxhits = $db_max_hits); $in{'nh'} ? ($nh = $in{'nh'}) : ($nh = 1); $numhits = 0; # Let's set restricted to 1 if the user can only view/mod their own and # this isn't an admin. ($restricted = 1) if ($_[0] eq "view" and $auth_view_own and !$per_admin); ($restricted = 1) if ($_[0] eq "mod" and $auth_modify_own and !$per_admin); # Now let's build up all the regexpressions we will use. This saves the program # from having to recompile the same regular expression every time. foreach $field (@search_fields) { my $tmpreg = "$in{$db_cols[$field]}"; (!$in{'re'}) and ($tmpreg = "\Q$tmpreg\E"); ($in{'ww'}) and ($tmpreg = "\\b$tmpreg\\b"); (!$in{'cs'}) and ($tmpreg = "(?i)$tmpreg"); ($in{$db_cols[$field]} eq "*") and ($tmpreg = ".*"); # A "*" matches anything. $regexp_func[$field] = eval 'sub { m/$tmpreg/o; }'; $regexp_bold[$field] = $tmpreg; } # Now we go through the database and do the actual searching. # First figure out which records we want: $first = ($maxhits * ($nh - 1)); $last = $first + $maxhits - 1; open (DB, "<$db_file_name") or &cgierr("error in search. unable to open database: $db_file_name.\nReason: $!"); if ($db_use_flock) { flock(DB, 1); } LINE: while () { (/^#/) and next LINE; # Skip comment Lines. (/^\s*$/) and next LINE; # Skip blank lines. $line = $_; chomp ($line); # Remove trailing new line. @values = &split_decode($line); # If we are only allowed to view/mod our own record, then let's check here. next LINE if ($restricted and ($db_userid ne $values[$auth_user_field])); # Normal searches. $key_match = 0; foreach $field (@search_fields) { $_ = $values[$field]; # Reg function works on $_. $in{'ma'} ? ($key_match = ($key_match or &{$regexp_func[$field]})) : (&{$regexp_func[$field]} or next LINE); } # Greater then searches. foreach $field (@search_gt_fields) { $term = $in{"$db_cols[$field]-gt"}; if ($db_sort{$db_cols[$field]} eq "date") { $in{'ma'} ? ($key_match = ($key_match or (&date_to_unix($values[$field])) > &date_to_unix($term))) : (&date_to_unix($values[$field]) > (&date_to_unix($term)) or next LINE); } elsif ($db_sort{$db_cols[$field]} eq 'alpha') { $in{'ma'} ? ($key_match = ($key_match or ($values[$field] > $term))) : ((lc($values[$field]) gt lc($term)) or next LINE); } else { $in{'ma'} ? ($key_match = ($key_match or ($values[$field] > $term))) : (($values[$field] > $term) or next LINE); } } # Less then searches. foreach $field (@search_lt_fields) { $term = $in{"$db_cols[$field]-lt"}; if ($db_sort{$db_cols[$field]} eq "date") { $in{'ma'} ? ($key_match = ($key_match or (&date_to_unix($values[$field]) < &date_to_unix($term)))) : (&date_to_unix($values[$field]) < (&date_to_unix($term)) or next LINE); } elsif ($db_sort{$db_cols[$field]} eq 'alpha') { $in{'ma'} ? ($key_match = ($key_match or ($values[$field] < $term))) : ((lc($values[$field]) lt lc($term)) or next LINE); } else { $in{'ma'} ? ($key_match = ($key_match or ($values[$field] < $term))) : (($values[$field] < $term) or next LINE); } } # Did we find a match? We only add the hit to the @hits array if we need it. We can # skip it if we are not sorting and it's not in our first < > last range. if ($key_match || (!($in{'keyword'}) && !($in{'ma'}))) { if (exists $in{'sb'}) { $sortby{(($#hits+1) / ($#db_cols+1))} = $values[$in{'sb'}]; push (@hits, @values); } else { (($numhits >= $first) and ($numhits <= $last)) and push (@hits, @values); } $numhits++; # But we always count it! } } close DB; # Now we've stored all our hits in @hits, and we've got a sorting values stored # in %sortby indexed by their position in @hits. $numhits ? ($db_total_hits = $numhits) : ($db_total_hits = 0); ($db_total_hits == 0) and return ("keine passenden Eintr�ge."); # Sort the array @hits in order if we are meant to sort. if (exists $in{'sb'}) { # Sort hits on $in{'sb'} field. my ($sort_order, $sort_func); $in{'so'} ? ($sort_order = $in{'so'}) : ($sort_order = "ascend"); $sort_func = "$db_sort{$db_cols[$in{'sb'}]}_$sort_order"; foreach $hit (sort $sort_func (keys %sortby)) { $first = ($hit * $#db_cols) + $hit; $last = ($hit * $#db_cols) + $#db_cols + $hit; push (@sortedhits, @hits[$first .. $last]); } @hits = @sortedhits; } # If we have to many hits, let's build the next toolbar, and return only the hits we want. if ($numhits > $maxhits) { # Remove the nh= from the query string. $next_url = $ENV{'QUERY_STRING'}; $next_url =~ s/\&nh=\d+//; $next_hit = $nh + 1; $prev_hit = $nh - 1; # Build the next hits toolbar. It seems really complicated as we have to do # some number crunching to keep track of where we are on the toolbar, and so # that the toolbar stays centred. # First, set how many pages we have on the left and the right. $left = $nh; $right = int($numhits/$maxhits) - $nh; # Then work out what page number we can go above and below. ($left > 7) ? ($lower = $left - 7) : ($lower = 1); ($right > 7) ? ($upper = $nh + 7) : ($upper = int($numhits/$maxhits) + 1); # Finally, adjust those page numbers if we are near an endpoint. (7 - $nh >= 0) and ($upper = $upper + (8 - $nh)); ($nh > ($numhits/$maxhits - 7)) and ($lower = $lower - ($nh - int($numhits/$maxhits - 7) - 1)); $db_next_hits = ""; # Then let's go through the pages and build the HTML. ($nh > 1) and ($db_next_hits .= qq~[<<] ~); for ($i = 1; $i <= int($numhits/$maxhits) + 1; $i++) { if ($i < $lower) { $db_next_hits .= " ... "; $i = ($lower-1); next; } if ($i > $upper) { $db_next_hits .= " ... "; last; } ($i == $nh) ? ($db_next_hits .= qq~$i ~) : ($db_next_hits .= qq~$i ~); if (($i * $maxhits) >= $numhits) { last; } # Special case if we hit exact. } $db_next_hits .= qq~[>>] ~ unless ($nh == $i); # Slice the @hits to only return the ones we want, only have to do this if the results are sorted. if (exists $in{'sb'}) { $first = ($maxhits * ($nh - 1)) * ($#db_cols+1); $last = $first + (($#db_cols+1) * $maxhits) - 1; $last = $#hits if ($last > $#hits); @hits = @hits[$first .. $last]; } } # Bold the results if ($db_bold and $in{'view_records'}) { for $i (0 .. (($#hits+1) / ($#db_cols+1)) - 1) { $offset = $i * ($#db_cols+1); foreach $field (@search_fields) { $hits[$field + $offset] =~ s,(<[^>]+>)|($regexp_bold[$field]),defined($1) ? $1 : "$2",ge; } } } return ("ok", @hits); } sub admin_display { # -------------------------------------------------------- # Let's an admin add/update/remove users from the authorization file. # my ($message, @lines, $line); # Do we have anything to do? CASE: { # If we've been passed in new_username, then we are adding a new user. Do # some basic error checking and then add him into the password file. $in{'new_username'} and do { unless ((length($in{'new_username'}) >= 3) and (length($in{'new_username'}) <= 12) and ($in{'new_username'} =~ /^[a-zA-Z0-9]+$/)) { $message = "Invalid username: $in{'new_username'}. Must only contain letters and numbers and be less then 12 and greater then 3 characters."; last CASE; } unless ((length($in{'password'}) >= 3) and (length($in{'password'}) <= 12)) { $message = "Invalid password: '$in{'password'}'. Must be less then 12 and greater then 3 characters."; last CASE; } open (PASS, ">>$auth_pw_file") or &cgierr ("unable to open: $auth_pw_file.\nReason: $!"); if ($db_use_flock) { flock(PASS, 2) or &cgierr("unable to get exclusive lock on $auth_pw_file.\nReason: $!"); } my @salt_chars = ('A' .. 'Z', 0 .. 9, 'a' .. 'z', '.', '/'); my $salt = join '', @salt_chars[rand 64, rand 64]; my $encrypted = crypt($in{'password'}, $salt); print PASS "$in{'new_username'}:$encrypted:$in{'per_view'}:$in{'per_add'}:$in{'per_del'}:$in{'per_mod'}:$in{'per_admin'}\n"; close PASS; $message = "User: $in{'new_username'} created."; last CASE; }; # If we've been passed in delete, then we are removing a user. Check # to make sure a user was selected then try and remove him. $in{'delete'} and do { unless ($in{'username'}) { $message = "No username selected to delete."; last CASE; } open (PASS, "<$auth_pw_file") or &cgierr ("unable to open: $auth_pw_file.\nReason: $!"); if ($db_use_flock) { flock(PASS, 1) } @lines = ; close PASS; open (PASS, ">$auth_pw_file") or &cgierr ("unable to open: $auth_pw_file.\nReason: $!"); if ($db_use_flock) { flock(PASS, 2) or &cgierr("unable to get exclusive lock on $auth_pw_file.\nReason: $!"); } my $found = 0; foreach $line (@lines) { ($line =~ /^$in{'username'}:/) ? ($found = 1) : print PASS $line; } close PASS; $found ? ($message = "User: $in{'username'} deleted.") : ($message = "Unable to find userid: $in{'username'} in password file."); last CASE; }; # If we have a username, and the admin didn't press inquire, then # we are updating a user. ($in{'username'} && !$in{'inquire'}) and do { open (PASS, "<$auth_pw_file") or &cgierr ("unable to open: $auth_pw_file.\nReason: $!"); if ($db_use_flock) { flock(PASS, 1); } @lines = ; close PASS; open (PASS, ">$auth_pw_file") or &cgierr ("unable to open: $auth_pw_file.\nReason: $!"); if ($db_use_flock) { flock(PASS, 2) or &cgierr("unable to get exclusive lock on $auth_pw_file.\nReason: $!"); } my $found = 0; foreach $line (@lines) { if ($line =~ /^$in{'username'}:/) { my $password = (split (/:/, $line))[1]; unless ($password eq $in{'password'}) { my @salt_chars = ('A' .. 'Z', 0 .. 9, 'a' .. 'z', '.', '/'); my $salt = join '', @salt_chars[rand 64, rand 64]; $password = crypt($in{'password'}, $salt); } print PASS "$in{'username'}:$password:$in{'per_view'}:$in{'per_add'}:$in{'per_del'}:$in{'per_mod'}:$in{'per_admin'}\n"; $found = 1; } else { print PASS $line; } } $in{'inquire'} = $in{'username'}; $found ? ($message = "User: $in{'username'} updated.") : ($message = "Unable to find user: '$in{'username'}' in the password file."); last CASE; }; }; # Now let's load the list of users. open (PASS, "<$auth_pw_file") or &cgierr ("unable to open: $auth_pw_file.\nReason: $!"); if ($db_use_flock) { flock(PASS, 1); } @lines = ; close PASS; # If we are inquiring, let's look for the specified user. my (@data, $user_list, $perm, $password); $user_list = qq~"; # Build the permissions list if we haven't inquired in someone. if (!$perm) { $perm = qq| View Add Delete Modify Admin |; } &html_admin_display ($message, $user_list, $password, $perm); } sub signup { # -------------------------------------------------------- # Allows a user to sign up without admin approval. Must have $auth_signup = 1 # set. The user gets @default_permissions. # my $message; # Check to make sure userid is ok, pw ok, and userid is unique. unless ((length($in{'userid'}) >= 3) and (length($in{'userid'}) <= 12) and ($in{'userid'} =~ /^[a-zA-Z0-9]+$/)) { $message = "Invalid userid: $in{'userid'}. Must only contain only letters and be less then 12 and greater then 3 characters."; } unless ((length($in{'pw'}) >= 3) and (length($in{'pw'}) <= 12)) { $message = "Invalid pw: '$in{'pw'}'. Must be less then 12 and greater then 3 characters."; } open (PASS, "<$auth_pw_file") or &cgierr ("unable to open: $auth_pw_file.\nReason: $!"); if ($db_use_flock) { flock(PASS, 1); } while () { /^\Q$in{'userid'}\E:/ and ($message = "userid already exists. Please try another."); } close PASS; if ($message) { &html_signup_form ($message); return; } # Add the userid into the file with default permissions. open (PASS, ">>$auth_pw_file") or &cgierr ("unable to open: $auth_pw_file.\nReason: $!"); if ($db_use_flock) { flock(PASS, 2) or &cgierr("unable to get exclusive lock on $auth_pw_file.\nReason: $!"); } srand( time() ^ ($$ + ($$ << 15)) ); # Seed Random Number my @salt_chars = ('A' .. 'Z', 0 .. 9, 'a' .. 'z', '.', '/'); my $salt = join '', @salt_chars[rand 64, rand 64]; my $encrypted = crypt($in{'pw'}, $salt); my $permissions = join (":", @auth_signup_permissions); print PASS "$in{'userid'}:$encrypted:$permissions\n"; close PASS; &html_signup_success; } sub get_record { # -------------------------------------------------------- # Given an ID as input, get_record returns a hash of the # requested record or undefined if not found. my ($key, $found, $line, @data, $field, $restricted); $key = $_[0]; $found = 0; ($restricted = 1) if ($auth_modify_own and !$per_admin); open (DB, "<$db_file_name") or &cgierr("error in get_records. unable to open db file: $db_file_name.\nReason: $!"); if ($db_use_flock) { flock(DB, 1); } LINE: while () { (/^#/) and next LINE; (/^\s*$/) and next LINE; $line = $_; chomp ($line); @data = &split_decode($line); next LINE if ($restricted and ($db_userid ne $data[$auth_user_field])); if ($data[$db_key_pos] eq $key) { $found = 1; for ($i = 0; $i <= $#db_cols; $i++) { # Map the array columns to a hash. $rec{$db_cols[$i]} = $data[$i]; } last LINE; } } close DB; $found ? (return %rec) : (return undef); } sub get_defaults { # -------------------------------------------------------- # Returns a hash of the defaults used for a new record. my (%default); foreach $field (keys %db_defaults) { $default{$field} = $db_defaults{$field}; } if ($db_key_track) { open (ID, "<$db_id_file_name") or &cgierr("error in get_defaults. unable to open id file: $db_id_file_name.\nReason: $!"); if ($db_use_flock) { flock(ID, 1); } $default{$db_key} = + 1; # Get next ID number close ID; } return %default; } sub validate_record { # -------------------------------------------------------- # Verifies that the information passed through the form and stored # in %in matches a valid record. It checks first to see that if # we are adding, that a duplicate ID key does not exist. It then # checks to see that fields specified as not null are indeed not null, # finally it checks against the reg expression given in the database # definition. my ($col, @input_err, $errstr, $err, $line, @lines, @data); if ($in{'add_record'}) { # don't need to worry about duplicate key if modifying open (DB, "<$db_file_name") or &cgierr("error in validate_records. unable to open db file: $db_file_name.\nReason: $!"); if ($db_use_flock) { flock(DB, 1); } LINE: while () { (/^#/) and next LINE; (/^\s*$/) and next LINE; $line = $_; chomp ($line); @data = &split_decode($line); if ($data[$db_key_pos] eq $in{$db_key}) { return "duplicate key error"; } } close DB; } foreach $col (@db_cols) { if ($in{$col} =~ /^\s*$/) { # entry is null or only whitespace ($db_not_null{$col}) and # entry is not allowed to be null. push(@input_err, "$col (Can not be left blank)"); # so let's add it as an error } else { # else entry is not null. ($db_valid_types{$col} && !($in{$col} =~ /$db_valid_types{$col}/)) and push(@input_err, "$col (Invalid format)"); # but has failed validation. (length($in{$col}) > $db_lengths{$col}) and push (@input_err, "$col (Too long. Max length: $db_lengths{$col})"); if ($db_sort{$col} eq "date") { push (@input_err, "$col (Invalid date format)") unless &date_to_unix($in{$col}); } } } if ($#input_err+1 > 0) { # since there are errors, let's build foreach $err (@input_err) { # a string listing the errors $errstr .= "$err"; # and return it. } return "
$errstr
"; } else { return "ok"; # no errors, return ok. } } sub join_encode { # -------------------------------------------------------- # Takes a hash (ususally from the form input) and builds one # line to output into the database. It changes all occurrences # of the database delimeter to '~~' and all newline chars to '``'. my (%hash) = @_; my ($tmp, $col, $output); foreach $col (@db_cols) { $tmp = $hash{$col}; $tmp =~ s/^\s+//g; # Trim leading blanks... $tmp =~ s/\s+$//g; # Trim trailing blanks... $tmp =~ s/\Q$db_delim\E/~~/og; # Change delimeter to ~~ symbol. $tmp =~ s/\n/``/g; # Change newline to `` symbol. $tmp =~ s/\r//g; # Remove Windows linefeed character. $output .= $tmp . $db_delim; # Build Output. } chop $output; # remove extra delimeter. $output .= "\n"; # add linefeed char. return $output; } sub split_decode { # -------------------------------------------------------- # Takes one line of the database as input and returns an # array of all the values. It replaces special mark up that # join_encode makes such as replacing the '``' symbol with a # newline and the '~~' symbol with a database delimeter. my ($input) = shift; $input =~ s/\Q$db_delim\E$/$db_delim /o; # Add a space if we have delimiter new line. my (@array) = split (/\Q$db_delim\E/o, $input); for ($i = 0; $i <= $#array; $i++) { $array[$i] =~ s/~~/$db_delim/og; # Retrieve Delimiter.. $array[$i] =~ s/``/\n/g; # Change '' back to newlines.. } return @array; } sub build_select_field { # -------------------------------------------------------- # Builds a SELECT field based on information found # in the database definition. Parameters are the column to build # and a default value (optional). my ($column, $value) = @_; my (@fields, $ouptut); @fields = split (/\,/, $db_select_fields{$column}); if ($#fields == -1) { $output = "error building select field: no select fields specified in config for field '$column'!"; } else { $output = qq|"; } return $output; } sub build_select_field_from_db { # -------------------------------------------------------- # Builds a SELECT field from the database. my ($column, $value, $name) = @_; my (@fields, $field, @selectfields, @lines, $line, $ouptut); my ($fieldnum, $found, $i) = 0; $name || ($name = $column); for ($i = 0; $i <= $#db_cols; $i++) { if ($column eq $db_cols[$i]) { $fieldnum = $i; $found = 1; last; } } if (!$found) { return "error building select field: no fields specified!"; } open (DB, "<$db_file_name") or &cgierr("unable to open $db_file_name. Reason: $!"); if ($db_use_flock) { flock(DB, 1); } LINE: while () { next if /^#/; next if /^\s*$/; $line = $_; chomp ($line); @fields = &split_decode ($line); if (!(grep $_ eq $fields[$fieldnum], @selectfields)) { push (@selectfields, $fields[$fieldnum]); } } close DB; $output = qq|"; return $output; } sub build_checkbox_field { # -------------------------------------------------------- # Builds a CHECKBOX field based on information found # in the database definition. Parameters are the column to build # whether it should be checked or not and a default value (optional). my ($column, $values) = @_; if (!$db_checkbox_fields{$column}) { return "error building checkboxes: no checkboxes specified in config for field '$column'"; } my @names = split (/,/, $db_checkbox_fields{$column}); my @values = split (/\Q$db_delim\E/, $values); my ($name, $output); foreach $name (@names) { (grep $_ eq $name, @values) ? ($output .= qq! $name\n!) : ($output .= qq! $name\n!); } return $output; } sub build_radio_field { # -------------------------------------------------------- # Builds a RADIO Button field based on information found # in the database definition. Parameters are the column to build # and a default value (optional). my ($column, $value) = @_; my (@buttons, $button, $output); @buttons = split (/,/, $db_radio_fields{$column}); if ($#buttons == -1) { $output = "error building radio buttons: no radio fields specified in config for field '$column'!"; } else { foreach $button (@buttons) { $value =~ /^\Q$button\E$/ ? ($output .= qq| $button \n|) : ($output .= qq| $button \n|); } } return $output; } sub array_to_hash { # -------------------------------------------------------- # Converts an array to a hash using db_cols as the field names. my($hit, @array) = @_; my(%hash); for ($j = 0; $j <= $#db_cols; $j++) { $hash{$db_cols[$j]} = $array[$hit * ($#db_cols+1) + $j]; } return %hash; } sub build_html_record { # -------------------------------------------------------- # Builds a record based on the config information. # my (%rec) = @_; my ($output, $field); $output = "
"; foreach $field (@db_cols) { next if ($db_form_len{$field} == -1); $output .= qq~~; } $output .= "
<$font>$field: <$font>$rec{$field}
\n"; return $output; } sub build_html_record_form { # -------------------------------------------------------- # Builds a record form based on the config information. # my (%rec) = @_; my ($output, $field); $output = "
"; foreach $field (@db_cols) { if ($db_select_fields{$field}) { $output .= ""; } elsif ($db_radio_fields{$field}) { $output .= ""; } elsif ($db_checkbox_fields{$field}) { $output .= ""; } elsif ($db_form_len{$field} =~ /(\d+)x(\d+)/) { $output .= qq~~; } elsif ($db_form_len{$field} == -1) { $output = qq~$output~; } elsif ($db_form_len{$field} == -2) { $per_admin ? ($output .= qq~~) : ($output = qq~$output~); } else { $output .= qq~~; } } $output .= "
<$font>$field: " . &build_select_field($field, $rec{$field}) . "
<$font>$field: " . &build_radio_field($field, $rec{$field}) . "
<$font>$field: " . &build_checkbox_field ($field, $rec{$field}) . "
<$font>$field:
<$font>$field:
<$font>$field:
\n"; return $output; } sub get_time { # -------------------------------------------------------- # Returns the time in the format "hh-mm-ss". # my ($sec, $min, $hour, $day, $mon, $year, $dweek, $dyear, $daylight) = localtime(time()); ($sec < 10) and ($sec = "0$sec"); ($min < 10) and ($min = "0$min"); ($hour < 10) and ($hour = "0$hour"); return "$hour:$min:$sec"; } sub get_date { # -------------------------------------------------------- # Returns the date in the format "dd-mmm-yy". # Warning: If you change the default format, you must also modify the &date_to_unix # subroutine below which converts your date format into a unix time in seconds for sorting # purposes. my ($sec, $min, $hour, $day, $mon, $year, $dweek, $dyear, $daylight) = localtime(time()); my (@months) = qw!Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec!; ($day < 10) and ($day = "0$day"); $year = $year + 1900; return "$day-$months[$mon]-$year"; } sub date_to_unix { # -------------------------------------------------------- # This routine must take your date format and return the time a la UNIX time(). # Some things to be careful about.. # int your values just in case to remove spaces, etc. # catch the fatal error timelocal will generate if you have a bad date.. # don't forget that the month is indexed from 0! # my ($date) = $_[0]; my (%months) = ("Jan" => 0, "Feb" => 1, "Mar" => 2, "Apr" => 3, "May" => 4, "Jun" => 5, "Jul" => 6, "Aug" => 7, "Sep" => 8, "Oct" => 9, "Nov" => 10,"Dec" => 11); my ($time); my ($day, $mon, $year) = split(/-/, $_[0]); unless ($day and $mon and $year) { return undef; } unless (defined($months{$mon})) { return undef; } use Time::Local; eval { $day = int($day); $year = int($year) - 1900; $time = timelocal(0,0,0,$day, $months{$mon}, $year); }; if ($@) { return undef; } # Could return 0 if you want. return ($time); } # These are the sorting functions used in &query. # -------------------------------------------------------- sub alpha_ascend { lc($sortby{$a}) cmp lc ($sortby{$b}) } sub alpha_descend { lc($sortby{$b}) cmp lc ($sortby{$a}) } sub numer_ascend { $sortby{$a} <=> $sortby{$b} } sub numer_descend { $sortby{$b} <=> $sortby{$a} } sub date_ascend { &date_to_unix($sortby{$a}) <=> &date_to_unix($sortby{$b}) } sub date_descend { &date_to_unix($sortby{$b}) <=> &date_to_unix($sortby{$a}) } sub parse_form { # -------------------------------------------------------- # Parses the form input and returns a hash with all the name # value pairs. Removes SSI and any field with "---" as a value # (as this denotes an empty SELECT field. my (@pairs, %in); my ($buffer, $pair, $name, $value); if ($ENV{'REQUEST_METHOD'} eq 'GET') { @pairs = split(/&/, $ENV{'QUERY_STRING'}); } elsif ($ENV{'REQUEST_METHOD'} eq 'POST') { read(STDIN, $buffer, $ENV{'CONTENT_LENGTH'}); @pairs = split(/&/, $buffer); } else { &cgierr ("This script must be called from the Web\nusing either GET or POST requests\n\n"); } PAIR: foreach $pair (@pairs) { ($name, $value) = split(/=/, $pair); $name =~ tr/+/ /; $name =~ s/%([a-fA-F0-9][a-fA-F0-9])/pack("C", hex($1))/eg; $value =~ tr/+/ /; $value =~ s/%([a-fA-F0-9][a-fA-F0-9])/pack("C", hex($1))/eg; $value =~ s///g; # Remove SSI. if ($value eq "---") { next PAIR; } # This is used as a default choice for select lists and is ignored. (exists $in{$name}) ? ($in{$name} .= "~~$value") : # If we have multiple select, then we tack on ($in{$name} = $value); # using the ~~ as a seperator. } return %in; } sub cgierr { # -------------------------------------------------------- # Displays any errors and prints out FORM and ENVIRONMENT # information. Useful for debugging. if (!$html_headers_printed) { print "Content-type: text/html\n\n"; $html_headers_printed = 1; } print "DBMan encountered an internal error. "; if ($db_debug) { print "
\n\nCGI ERROR\n==========================================\n";
$_[0] and print "Error Message : $_[0]\n";
$0 and print "Script Location : $0\n";
$] and print "Perl Version : $]\n";
$db_setup and print "Setup File : $db_setup.cfg\n";
$db_userid and print "User ID : $db_userid\n";
$db_uid and print "Session ID : $db_uid\n";
print "\nForm Variables\n-------------------------------------------\n";
foreach $key (sort keys %in) {
my $space = " " x (20 - length($key));
print "$key$space: $in{$key}\n";
print "\nEnvironment Variables\n-------------------------------------------\n";
foreach $env (sort keys %ENV) {
my $space = " " x (20 - length($env));
print "$env$space: $ENV{$env}\n";
print "\n
babal45
Messagepar Franck Morin » 16 Fév 2006 23:42
merci, mais ce n'était pas la peine. il avait dit un lien ou un petit discours...
Messagepar v33 » 17 Fév 2006 01:41
ouaip ! que quoi laisser les gosses amers ! MDR :_k=
v33
Messagepar PY-74 » 17 Fév 2006 09:16
'tain l'ot !
y's reveille 1 mois et demi apres , et y't balance 2 pages de code.
merci qd meme.
pour les débutants dans la TNT , dans mon genre , je conseille 2 bouquins
TNT : principe et application du systeme DVB de Hervé Benoit , et
TNT : Fondamentaux et persepectives de Bernard Denis Laroque.
PY-74
