Generateur signal TNT......
Messagepar kinglolo » 19 Mai 2008 09:13
Trouvé sur le NET, ca a l'air interressant....
http://fabrice.bellard.free.fr/dvbt/
Le site se propose de realiser un generateur de mire/image , a partir d'un PC / Linux avec une carte de type VGA.....
Source du site :
How does it work ?
Every VGA card contains high speed Digital to Analog Converters (DACs), one for each Red, Blue and Green component. Here we use only the red DAC. The provided images have been computed so that the signal output to the DAC is a valid RF signal.
As we did not want to generate a 176 MHz signal directly, we use the fact that the VGA DACs generate a lot of harmonics. The real generated DVB-T signal has a central frequency of 25.71 MHz. Then the second harmonic has a frequency of 25.71+2*76.5 = 178.71 MHz which is almost exactly the central frequency of the VHF TV channel 5.
The DVB-T signal is generated with a DVB-T and DVB-H modulator I wrote from scratch. This is the most complicated step because the DVB-T modulation is quite complicated (COFDM modulation). A custom polyphase filter is used to interpolate the baseband COFDM complex signal. Then it is translated to the 25.71 MHz frequency.
I used a patched version of FFmpeg to generate a custom DVB Transport Stream containing two DVB services. Each one contains a still MPEG picture. One of the still picture is the very nice Lena.
For PAL and SECAM, I also wrote a simple TV black and white PAL encoder. Adding color would be possible, but I am not motivated enough to do it :-)
Image[/img]
Philips_32PFL5522D /Dep :22 /Em:Roch-Tredudon 80km
http://www.son-video.com/Rayons/Video/E ... 5522D.html
le Tableau synthetique complet de la TNT
kinglolo
Messagepar kinglolo » 02 Juin 2008 08:29
Ben alors ? Personne interressé ? pas de reactions ?? dommage..... :wink:
kinglolo
Messagepar vidéo-33 » 02 Juin 2008 08:50
si tu arrives à le faire marcher on en reparles !
de toutes façons ça ne sert à rien si on ne peut pas
exploiter son propre signal en entrée de modulation
