Les chaînes de la TNT française en Angleterre ?
Messagepar Roofeye » 25 Juin 2007 19:12
Excellente idée, j’ai appris l’Anglais en regardant la TV donc je recommande cette méthode. Le seul inconvénient c’est que l’on apprend pas à parler mais ça viens après
Les émetteurs Français ayant une chance à Poole sont peut être ceux de Caen (Mont Pinçon – 25 Kw) ou Cherbourg (Digosville 5 Kw) à condition bien sur que les canaux concernés soient libres de l’autre cote de la Manche.
Je ne connais pas Cherbourg, mais Poole la plage était une destination favorite quand j’habitais à Coventry.
Roofeye
Messagepar Pollux » 27 Juin 2007 15:12
Hi Matthew
(J'adresse mes excuses aux lecteurs francais si je continue en anglais...)
If you haven't already done so, I would suggest that you keep an eye on similar topics on the Digital Spy forums (in particular the one dealing with terrestrial digital - http://www.digitalspy.co.uk/forums/foru ... .php?f=156). I just did a search on "France" and saw that there were some threads about receiving TNT in Ramsgate and Folkestone (which I appreciate are a fair distance from Poole...).
As for a set top box, you should be OK with one bought in the UK. Sensitivity of the box may be critical to receive signals at the sort of distance you are considering but there's no easy way to check that. Folk on the above forum may be able to help though. Early UK digital boxes were not compatible with the French TNT (as I learnt to my cost!) but that should not be an issue now.
Bon chance! (From an ex-pat Brit)
Pollux
Messagepar Matthew » 27 Juin 2007 17:16
So, I don't need to buy a new set-top box, I can simply use my current one (for Freeview)? But I need to scan for the channels? That Digital Spy link was very helpful, Pollux. :D
The set-top box I have is this one:
http://www.amazon.co.uk/Goodmans-GDB3-Freeview-Box-Interactivity/dp/B0007LYJ68
I bought it about two years ago (in June 2005). Now, I'm not sure if it's suitable, but after having manually scanned the box (on UHF channel 52, as someone on Digital Spy recommended), I couldn't find any signal.
So, the next thing I need to do, in order to receive the channels, is improve the signal my antenna receives, right? Then I should be able to get French TV...
Digital Spy thread I used:
http://www.digitalspy.co.uk/forums/showthread.php?t=559033
Matthew
Messagepar Roofeye » 27 Juin 2007 18:10
Hi Matthiew,
Yes your Goodmans receiver is fine, I didn’t realise you’d already have one!
You need a good boosted aerial pointing South and try the Cherbourg Digosville (5Kwatt) transmitter
R6 Cherbourg Digosville UHF Channel 32
R2 Cherbourg Digosville UHF Channel 34
R3 Cherbourg Digosville UHF Channel 49
R4 Cherbourg Digosville UHF Channel 53
R5 Cherbourg Digosville UHF Channel 57 (not yet in service)
R1 Cherbourg Digosville UHF Channel 63
Or even Caen Mont Pinçon, it lies further but is more powerfull (25Kwatt)
R4 Caen Mont Pinçon UHF Channel 23
R1 Caen Mont Pinçon UHF Channel 26
R5 Caen Mont Pinçon UHF Channel 29 (not yet in service)
R2 Caen Mont Pinçon UHF Channel 34
R3 Caen Mont Pinçon UHF Channel 49
R6 Caen Mont Pinçon UHF Channel 58
You stand more chance to get something than anyone on the East coast since Northern France (Lille and around) tranmissions have not yet started in DTT because of lengthy agreement seeking with Belgium Holland an the UK.
Of course any local transmitter to you might be a hindrance if using same or neighbouring frequencies.
Roofeye
Re: Les chaînes de la TNT française en Angleterre ?
Messagepar tacotac » 24 Mar 2008 17:52
Matthew a écrit:Bonjour. Je suis Anglais, et mon Français n'est pas bon. :roll:
Je voudrais savoir si c'est possible recevoir les chaînes TNT en Angleterre avec un adaptateur. J'ai une antenne déjà. J'habite dans le sud de l'Angleterre, au bord de la mer.
Merci beaucoup. :D
et matthew té tomber sur la tete ou quoi je vais te dire regarde té quarante belle chaines anglaise
parce que les dix huit chaines française de la tnt sont nulle par rapport a té chaines anglaise
tacotac
Messagepar julien74 » 25 Mar 2008 10:53
Hello Matthew (sorry for my english...)
You can also receive French TV by satellite with a dish...
What channels did you want to watch? (News , Music , entertainment , cultural , ...)
Bye :wink:
Messagepar sokawet13 » 26 Mar 2008 17:20
je vais partir en angleterre bientôt,
me serait-il possible de recevoir la TNT française par internet ?
merci d'avance de vos réponses!
:lol:
sokawet13
Messagepar DOBERMAN » 26 Mar 2008 17:28
par internet non. :wink:
tu as ce genre de chose mais ca marche par rapport à l'ip
https://zattoo.com/nowshowing
DOBERMAN
Messagepar Dead man » 05 Fév 2009 17:48
SI J ACHETE UN APPAREIL EN FRANCE POUR LA TNT EST CE QU'IL FONCTIONNERA AU PORTUGAL POUR AVOIR TOUTE LES CHAINES FRANCAISE
Dead man
Messagepar vidéo-33 » 05 Fév 2009 19:04
???? à part la reprise des chaines tnt sur un bouquet commercial
le TNTSAT par satellite tu ne peux pas recevoir la TNT terrestre
aussi loin de la France qui n'est déjà pas suffisament couverte elle même !
