Un SATFINDER pro
Un SATFINDER pro
Messagepar miky01 » 11 Mai 2009 20:01
IBERSAT ISF 2009 HD SATELLITE FINDER METER
Je viens de tomber sur une pub pour ce nouveau Satfinder, qui a l'air pas mal du tout, mais je sais pas du tout si il tient ses promesses...
THE BEST METER WE HAVE COME ACROSS FOR A LONG TIME
IBERSAT ISF2009 SAT METER Future :
-USALS
-AUTO/BLIND/NI/MANUAL SEARCH
-SOUND ALARM AND LIGHT ALARM
-BER, S/N FEC ANGLE CALCULATION
-DISEQC 1, 1.1, 1.2 AUTO DISEQC
-3.5 INCH COLOUR TFT LCD DISPLAY
-MULTI LANGUAGE
-AV IN / OUT
-LI-ION BATTERY 2200mA
CONTENTS
1 X ISF2009 METER
1 X REMOTE CONTROL
1 X AC POWER ADAPTOR
1 X 12V CAR CHARGER
1 X PROTECTIVE CASE
2 X MANUALS 1 X ENGLISH, 1 X ITALIAN
Specification
System capabilities
Fully DVB Compliant
LNB/Tuner input
Connector - F Type Male
Frequency Range - 950Mhz - 2150mhz
Signal Lever - -6.5dBm ~-25dBm
LNB Supply - 13/18V, max 400mA
LNB switch control 22KHz
Diseqc 1.0 - 1.2
DEMODULATOR
Front End - QPSK
Symbol Rate - 2Mbps~45Mbps
SCPC and MCPC Capable - Yes
Spectral Inversion - Auto Conversion
SYSTEM RESOURCE
Processor - 32bit processor
SDRAM - 8Mbytes
Flash - 1Mbyte
VIDEO DECODER
Mpeg 2 - Main Profile @ Main Level
Data Rate - up to 15M Bits/s
Resolution - 720, 576, 720*480
Video Format - PAL/NTSC/SECAM
MPEG AUDIO
Mpeg 1 Layer 1&2
Type - Mono
Sampling Rates - 32,44.1 and 48Khz
SERIAL DATA INTERFACE
Connector - USB to Serial RS232
POWER SUPPLY
Li-oN Battery - 220 mA
Supply Voltage - 13.3 Volt
Charger - 90-240V
PANEL CONNECTIONS
Digital Tuner Input - F-Type, Male
PHYSICAL SPECIFICATION
Size - 102x34x180 (mm)
Weight - 0.9kg
Son prix: 290€, infos -->ici<--
Re: Un SATFINDER pro
Messagepar Amadeus » 06 Nov 2009 13:12
Bonjour!
Je pourrais vous proposer ce SAT-Analyzer & Position-Finder Pro exceptionnel !
http://www.spaunshop.com/files/dbf1e_en ... 86-087.pdf
Pour plus d'info, contactez-moi sur lina_6656@yahoo.fr
Amadeus
