World first DVB-T RTX on 434.500 with 2MHz bandwidth
HamRadio 2016 Germany - Digital Television
Messagepar oe7dbh » 06 Juin 2016 17:02
Hides letter to you:
HiDes is the solution provider for FullHD video/audio transmission, and bidirectional data/control link.
The core technology is based on COFDM which is excellent for wireless long range transmission.
We can also provide the customization design service to fulfill different requirements.
We are now pleased to announce the launch of UT-160 USB receiver.
It is a milestone for HiDes to support 1Mhz narrow channel bandwidth not only in the transmitter, but also the receiver.
In addition to superior sensitivity with diversity technology for mobile reception with Doppler enhancement, it supports flexible
and wide range channel bandwidth for 1/1.5/2/2.5/3/4/5/6/7/8 MHz.
We will debut UT-160 in HAM RADIO 2016, both windows software and Linux V4L driver are available for end users and system integrators.
The standalone 1Mhz receiver is under development now and we hope to launch it in July.
Going forward, we will keep developing the excellent products for better performance and miniature design,
such as better encoding solution for good quality but lower data rate, lower latency, etc.
Please let us know if you have any requests or inquiries. We are happy to provide the best service as always.
73 Calvin www.hides.com.tw
Hides is again this year on HamRadio 2016 in Friedrichshafen with a small selection of products,
please look to timely material reservation or equal Friday morning on the stand over.
We are to find http://www.oe7forum.at/viewtopic.php?f= ... =330#p2006 here.
OE7DBH brings: preamplifiers for HV120, remaining dvb-t power amplifier, Octagon LNBs for
receiving future geostationary satellite EsHail, several GHz FM transmitter ATV and ATV component.
Preliminary Beginning to images:
http://www.dl1mfk.de/Sonstiges/Darko/index.htm or http://www.oe7forum.at/viewforum.php?f=15
73 Darko
Hides lettre pour vous:
Hides est le fournisseur de solutions pour la transmission de FullHD vidéo / audio, et des données bidirectionnelles / biellette de commande.
La technologie de base est basé sur COFDM qui est excellent pour la transmission sans fil à longue portée.
Nous pouvons également fournir le service de conception de personnalisation pour répondre à des exigences différentes.
Nous sommes maintenant heureux d'annoncer le lancement du récepteur USB UT-160.
Il est une étape importante pour Hides pour soutenir la bande passante du canal étroit 1Mhz non seulement dans l'émetteur, mais aussi le récepteur.
En plus de sensibilité supérieure avec la technologie de la diversité pour la réception mobile avec l'amélioration Doppler,
il prend en charge la bande passante du canal de gamme flexible et large pour 1 / 1,5 / 2 / 2,5 / 3/4/5/6/7/8 MHz.
Nous allons débuter UT-160 HAM RADIO 2016, les logiciels Windows et le pilote V4L Linux sont disponibles pour les utilisateurs finaux et les intégrateurs de systèmes. Le récepteur autonome 1Mhz est en cours de développement maintenant et nous espérons lancer en Juillet.
À l'avenir, nous allons continuer à développer les excellents produits pour une meilleure performance et le design miniature,
comme une meilleure solution de codage pour une bonne qualité, mais le taux de données plus faible, une latence plus faible, etc.
S'il vous plaît laissez-nous savoir si vous avez des demandes ou des demandes de renseignements.
Nous sommes heureux de fournir, comme toujours le meilleur service.
Translated by Google
Hides est à nouveau cette année sur hamradio 2016 à Friedrichshafen avec une petite sélection de produits,
s'il vous plaît regarder à la réservation de matériel en temps opportun ou égal vendredi matin au stand de plus.
Nous sommes http://www.oe7forum.at/viewtopic.php?f= ... =330#p2006 trouverez ici.
OE7DBH apporte: préamplificateurs pour HV120, restant Freeview amplificateur de puissance, Octagon LNBs
réception satellite géostationnaire de la future EsHail, plusieurs émetteur ATV et ATV composant GHz FM.
Début préliminaire aux images:
http://www.dl1mfk.de/Sonstiges/Darko/index.htm o http://www.oe7forum.at/viewforum.php?f=15
73 Darko
oe7dbh
Re: World first DVB-T RTX on 434.500 with 2MHz bandwidth
Messagepar BAISIN » 06 Juin 2016 17:33
J' ai vu qu' un tuner DVB-T MPEG 2 SD COFDM 8K avec recherche par fréquence, et possibilité de pas de 6 Mhz, pouvait s' accorder sur la fréquence de TV Amateur sur 433 Mhz, utilisant la norme DVB-T MPEG 2 SD COFDM 8K
I have noticed with a normal DVB-T MPEG 2 SD COFDM 8K, with search frequecy, and 6 Mhz, may tunning, to Amateur TV 433 Mhz frequency, using DVB-T MPEG 2 SD COFDM 8K standard.
UP converter for 2400 MHz
Messagepar oe7dbh » 06 Aoû 2016 15:50
Free programable local oscilator, UP converter for 13cm Band
Manufacture by ITE HiDes type: BU500
IF Input range: 100.......950 MHz
RF Output range: 2370......2470 MHz
RF Output power: 0,5 Watt
Added for all modulation
http://www.oe7forum.at/viewtopic.php?f= ... =150#p2045
vy 73 de OE7DBH Darko
oe7dbh@tirol.com
oe7dbh
