La RAI va lancer un multiplex en DVB-T2
Messagepar marceljack » 04 Fév 2013 18:46
La RAI va lancer un multiplex DVB-T2 (mux 5) dans les principales villes italiennes sur le canal VHF 11.
L'italie a rendu obligatoire le support du DVB-T2 dans tous les récepteurs à partir de janvier 2015.
Deux nouveaux labels seront introduits pour indiquer ce support (Silver T2 et Gold T2).
La dernière phrase de l'article n'est pas très précise mais j'interprète que le label "Gold T2" garantit, outre le support de DVB-T2, celui du décodage HEVC jusqu'à 1080p50.
source: http://advanced-television.com/2013/02/ ... roadcasts/
RAI to launch DVB-T2 broadcasts
From Branislav Pekic in Rome
Italian public broadcaster RAI is set to launch DVB-T2 broadcasts in almost all the provincial capitals with a new dedicated multiplex (number five) on VHF channel 11.
This move follows tests conducted by RAI in Palermo and in Valle d’Aosta. The new DVB-T2 transmitters will serve the regional capitals, while the composition of the new multiplex will include Rai 1 HD, Rai 2 HD, Rai 3 HD and Rai Test 3D.
Rival broadcaster Mediaset has also been conducting DVB-T2 trials on channel 38 – but only in limited areas in order to test the quality of reception and any transmission problems or interference.
Europa 7 HD is the first Italian broadcaster to fully adopt DVB-T2 for its digital TV platform and the only one that markets a digital box (the 7Box HD) that is capable of receiving the DVB-T2 signals.
Italy has mandated DVB-T2 support in receivers from January 1st 2015. Two new labels (Silver T2 and Gold T2) will be introduced for DTT receivers, likely to come to the Italian market already in 2014, with T2 front-end and HEVC decoding capabilities up to 1080p50.
Re: La RAI va lancer un multiplex en DVB-T2
Messagepar BAISIN » 06 Fév 2013 17:01
C'est l'exception qui fait la regle:L'Italie utilise toujours la bande III VHF pour la tv,que ce soit public ou privé !
d'après Wikipedia,le canal E8 VHF bande III de Monte Serra(Europa 7 HD),est captable dans toute la Mer Thyrreniene,y compris la Rivièra Française et Monaco,et une partie de Nice.
Déja certains tv sont prets pour le DVB-T2,les constructeurs n'ont pas attendu 2015 !
Mais les distributeurs Français se cachent bien d'en parler ! Chez Darty,le DVB-T2:Connais pas ! :shock:
Normal,ils préfèrent vendre du Darty box à tire Larigot !
Messagepar Franck Morin » 06 Fév 2013 20:46
Moi ce que je vois c'est que là-bas, au moins, ils ont un service public qui va de l'avant, qui ose avoir un nombre de spectateurs faible pendant un certain temps.
Ce n'est pas comme chez nous avec la RNT...
Messagepar Test » 06 Fév 2013 23:44
La France ferait bien de s'inspirer de l'exemple italien et de rendre la norme DVB-T2 obligatoire sur les nouveaux téléviseurs.
Je ne vois pas à quoi ça sert d'attendre puisque la migration est inéluctable. En plus, comme il faut environ 18 mois pour permettre aux professionnels d'écouler leur stock, pourquoi attendre ?
Plus tôt la décision sera prise, mieux ce sera pour envisager l'arrêt du DVB-T et le passage en tout DVB-T2.
Test
Messagepar pa.babao » 07 Fév 2013 01:54
Test a écrit:La France ferait bien de s'inspirer de l'exemple italien et de rendre la norme DVB-T2 obligatoire sur les nouveaux téléviseurs.
Ce qui serait bien, ce serait de s'assurer que les récepteurs DVB-T2 intègrent aussi le HEVC. Sinon on va devoir encore changer plusieurs fois de récepteurs à court terme...
Situation du coup assez différentes de nos chers voisins (anglais, italiens, etc.) qui se contentent manifestement du MPEG-4.
pa.babao
Messagepar bb95 » 07 Fév 2013 08:42
pa.babao a écrit:Ce qui serait bien, ce serait de s'assurer que les récepteurs DVB-T2 intègrent aussi le HEVC. Sinon on va devoir encore changer plusieurs fois de récepteurs à court terme...
Le HEVC tout de suite n'est pas aussi important que le T2. En effet, la démodulation étant effectuée au niveau du tuner, le T2 nécessite que le téléviseur soit équipé d'un tuner supportant cette démodulation. Le remplacement du tuner n'est en général pas prévu par les fabricants.
Par contre, pour la compression, de nombreux téléviseurs sont en fait des ordinateurs fonctionnant sous Linux et la décompression est effectuée par logiciel (par exemple, les Samsung utilisent un processeur ARM Cortex avec l'extension DSP Neon, la décompression H264 utilise des codecs en source ouverte) et rien ne s'opposerait à une mise à jour logicielle du codec HEVC des téléviseurs qui n'en disposent pas actuellement... sous réserve d'une puissance suffisant du processeur et d'une place suffisante dans la mémoire Flash de l'appareil, et surtout que les fabricants veuillent bien faire la mise à jour. Ceci étant, comme les microcodes sont souvent en source ouverte, un génie de la programmation peut toujours tenter le coup... (pour trouver des caïds Samsung, voir le site samygo.tv).
Cela devrait permettre en tout cas de lancer dès maintenant des appareils DVB-T2 avec la norme HEVC non finalisée, et la mettre à jour plus tard. Mais est-ce l'intérêt des fabricants ?
bb
bb95
Messagepar pa.babao » 07 Fév 2013 14:19
bb95 a écrit:Bonjour,
Perso j'ai un doute monstrueux sur "la puissance du processeur", et je suis prêt à parier qu'aucune récepteur DVB-T2 vendu actuellement ne sera en mesure de décoder du HEVC à partir de la résolution HD (et peut-être même pas jusque là) dans quelques années, en supposant que les constructeurs fassent l'effort de fournir une mise à jour logicielle (ce pour quoi je suis prêt à parier que ça n'arrivera pas :)).
Mais ... je joue probablement la Cassandre sur ce point :)
pa.babao
Messagepar bb95 » 08 Fév 2013 06:04
pa.babao a écrit:Perso j'ai un doute monstrueux sur "la puissance du processeur", et je suis prêt à parier qu'aucune récepteur DVB-T2 vendu actuellement ne sera en mesure de décoder du HEVC à partir de la résolution HD (et peut-être même pas jusque là) dans quelques années, en supposant que les constructeurs fassent l'effort de fournir une mise à jour logicielle (ce pour quoi je suis prêt à parier que ça n'arrivera pas :)).
Je ne me fais aucune illusion concernant les modèles actuels. En général, il n'y a plus de mise à jour dès qu'une nouvelle gamme est lancée. C'est à dire, au bout de 6 mois à un an. Quant à la puissance du processeur, ou plutôt celle du DSP qui assure le décodage, les nouvelles versions devraient pouvoir y arriver. Encore faudrait-il que les fabricants aient envie (et intérêt) de les intégrer dès maintenant dans leurs nouvelles gammes. Et là...
bb
bb95
Messagepar BAISIN » 09 Fév 2013 17:47
Ayant un PC portable,je verrais s'il existe des extensions DVB-T2 via USB.
Ces abrutis du SIMAVELEC affirment qu'il n' y a aucune utilité d'acheter dès maintenant du DVB-T2,histoire que les gens achètent des appareils actuels,et les jeter au bout d'un an !
Quand le SIMAVELEC s'appelait le SCART,ils produisaient du 100 % Français,et je pouvais admettre qu'ils prechent pour leur paroisse,mais aujourd'hui,toute leur production,s'est totalement délocalisée en Asie du Sud Est ! :x
Messagepar Franck Morin » 09 Fév 2013 19:49
Philips produit en Hongrie, Sony en Slovaquie, LG en Pologne...
et pourquoi veux-tu t'équiper en France en DVB-T2 dès maintenant ?
