TNT contribution
Re: TNT contribution
Messagepar marceljack » 28 Sep 2012 16:12
EnoSat a écrit:thanks,
known model type newtec demodulator use on DVB-T transmiters for this signal ?
I have found on a german forum that it was a Newtec NTC 2163 receiver but I think it's only a part of the solution:
http://forum.digitalfernsehen.de/forum/ ... f-ab3.html
Specification can be downloaded here:
http://www.google.fr/url?sa=t&rct=j&q=& ... 7oVWML8eoA
By the way, a few units are available for a cheap price (100€ !) at a dutch broker:
http://www.foltronics.nl/index_bestande ... ipment.htm
Messagepar EnoSat » 29 Sep 2012 07:58
this info from 2005 year :(
ROVER TAB900+ , Televes H30 FLEX
Gibertini OP100LN /85E-53W/
WaveFrontier T90 /51E-39E-36E-33E-28E-26E-23E-19E-16E-13E-9E-7E-5E-2E-1W-4W/
Edision MIO+ 4K, Octagon SF8008, Mutant HD51, QVIART Lunix, Ustym 4K S2 OTT, VU Solo4K, Dreambox 900UHD/7020HD/500HD, TBS-5925/5530/5220
EnoSat
Messagepar marceljack » 29 Sep 2012 08:12
EnoSat a écrit:this info from 2005 year :(
You mean the Newtec receiver type ?
Of course, but its availability at 100€ is certainly not so old.
You can find a lot of newer Newtec receivers on their website, which support this sytem as well as others based on DVB-S2, but of course not at the same price.
Could you tell what you are looking for exactly and for which purpose instead of just asking very laconic questions ?
Messagepar EnoSat » 29 Sep 2012 16:32
for added support in CrazyScan (detail info about demodulator - no white paper) , others transponders from 5W in CrazyScan now work
EnoSat
