Sehr geehrter Kunde,
dear customer,
we received another partial shipment of Technisat Skystar2 PCI, next delivery will be end of May 2006, due to shortage!
Wir haben eine Teillieferung der Technisat Skystar2 PCI erhalten, die nächste Lieferung wird erst Ende Mai 2006 erfolgen.
The delivery of Technotrend DVBS2-cards HDTV again delays for another 3 weeks, due to bugfixed with HDTV-codecs.
Die Auslieferung der Technotrend DVBS2-Karten HTDV verzögert sich, aufgrund von Bugfixes in den Codecs, noch bis 15. Mai.
Best regards,
mit freundlichen Grüßen,
DVBSHOP
www.dvbshop.net
For DVB-S
• SCPC/MCPC support up to 45 Msymbols/s
• QPSK with supported rates 1/2, 2/3, 3/4, 5/6, 6/7, 7/8
• Viterbi soft decoder rate ½
• outer Reed-Solomon decoder as per DVB-S system
• Up to 60 Mbps channel bit rate
For DVB-S2
• SCPC/MCPC support up to 30 Msymbols/s
• QPSK and 8PSK with supported rates
• 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9
• LDPC and BCH decoder as per DVB-S2 requirements
• Digital Nyquist root filter with 0.20, 0.25, 0.35 roll-off factors
• Up to 90 Mbps channel bit rate
Advanced Functionality
• HDTV support; AC3 5.1 Software decoder
• TV, Radio and data services on notebooks or PC via USB 2.0 interface
• Representation, Record (incl. Timer) and Playback of TV and Radio services
• Operation System support: Windows XP
• Time shift features and record timer
• Extended EPG functionality
• Teletext support
• Automatic Channel Setup using IP multicast group address
• IP-Unicast Transport using dynamic IP address to MAC address mapping
• Support MAC Address Filtering
• Use of up to 255 PID filters
• Download MPEG-2 PES speed up to 90 Mbit/s
Accessories
• Receiver and CI PCI board each ca. 120 x 106 x 18 [mm]
• 1 connection flat ribbon cable to link receiver and CI board
• Master CD-ROM with driver and application software
• License for MPEG2 and MPEG4 (AVC/H.264) - Software
decoder
• Optional Common Interface exten
