Reception chaines Numericable clé USB
Re: Reception chaines Numericable clé USB
Messagepar Schell » 27 Sep 2012 17:29
Maurice83300 a écrit:Ce petit programme détecte-t-il quelque chose:
http://www.wintvcd.co.uk/tools/ScanChannelsBDA_UK.exe
L'enregistrer sur le PC puis l'exécuter sans l'arrêter en option 1 (UK) et voir le fichier log qu'il crée dans son dossier de lancement.
Voici le résultat :
Code: Tout sélectionner
ScanChannelsBDA starting
Thu Sep 27 18:20:15 2012
Build - v2.8.1.0
Checking for new BDA DVB-T Cards
  Tuner - DiBcom BDA Digital Tuner (Dev1 Path0)
    @device:pnp:\\?\usb#vid_2304&pid_023d#05008761c8#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}
      Finding Demod and Capture filters
        Trying - DiBcom BDA Digital Capture (Dev1 Path0)
          @device:pnp:\\?\usb#vid_2304&pid_023d#05008761c8#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\dibcom bda digital capture (dev1 path0)
            SUCCESS
        Checking for Capture filter
      Finished Finding Demod and Capture filters
      Capture - DiBcom BDA Digital Capture (Dev1 Path0)
Finished Checking for new BDA DVB-T Cards
Found BDA device: DiBcom BDA Digital Tuner (Dev1 Path0)
# 474000kHz
# signal locked = N present = N strength = 94 quality = 0
# trying +166kHz
# trying -166kHz
# Nothing found on 474000kHz
# 482000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 482000kHz
# 490000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 490000kHz
# 498000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 498000kHz
# 506000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 506000kHz
# 514000kHz
# signal locked = N present = N strength = 93 quality = 0
# trying +166kHz
# trying -166kHz
# Nothing found on 514000kHz
# 522000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 522000kHz
# 530000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 530000kHz
# 538000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 538000kHz
# 546000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 546000kHz
# 554000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 554000kHz
# 562000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 562000kHz
# 570000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 570000kHz
# 578000kHz
# signal locked = N present = N strength = 92 quality = 0
# trying +166kHz
# signal locked = N present = N strength = 91 quality = 0
# trying -166kHz
# Nothing found on 578000kHz
# 586000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 586000kHz
# 594000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 594000kHz
# 602000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 602000kHz
# 610000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 610000kHz
# 618000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 618000kHz
# 626000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 626000kHz
# 634000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 634000kHz
# 642000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 642000kHz
# 650000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 650000kHz
# 658000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 658000kHz
# 666000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 666000kHz
# 674000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 674000kHz
# 682000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 682000kHz
# 690000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 690000kHz
# 698000kHz
# signal locked = Y present = Y strength = 79 quality = 0
# scan timed out
# 706000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 706000kHz
# 714000kHz
# scan timed out
# 722000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 722000kHz
# 730000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 730000kHz
# 738000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 738000kHz
# 746000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 746000kHz
# 754000kHz
# scan timed out
# 762000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 762000kHz
# 770000kHz
# scan timed out
# 778000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 778000kHz
# 786000kHz
# scan timed out
# 794000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 794000kHz
# 802000kHz
# scan timed out
# 810000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 810000kHz
# 818000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 818000kHz
# 826000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 826000kHz
# 834000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 834000kHz
# 842000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 842000kHz
# 850000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 850000kHz
Summary of frequencies
Please note that strength may not be an accurate figure.  The actual meaning
of strength depends upon the manufacturer of your device.
Autrement dit, il voit les bouquets mais c'est marqué :
# scan timed out
Schell
rvs a écrit:Bien, qu'il ne soit pas prévu pour faire des tests, tu peux essayer ZScanTV.NET
http://www.zguidetv.net/viewtopic.php?f=13&t=1032&p=8611#p8611
(inscription requise sur le forum de ZguideTV.NET)
Tu choisis Blindscan, Bandwidth=8, Bande IV et V comme fréquence à scanner.
Tu coches 0, 166 pour les bandes IV et V pour les Offsets
Tu coches Analyser les fréq. non verrouillées et Ne pas se fier à la qualité
Tu mets le Temps de stabilisation au maximum, idem pour le Temps post-tune.
Tu cliques sur le Bouton Scanner, tu bois un café, tu te fais à manger, tu manges, et tu reviens voir si c'est fini :mrgreen: .
Après, il faut tester avec différents paramètres.
Mais sur Saint Gratien (95), je n'ai aucun problème avec la TNT sur Numéricable avec mes clés.
Je n'ai pour le moment pas réussi à trouver le logiciel...
Schell
Messagepar rvs » 27 Sep 2012 18:22
Si on demande un enregistrement sur le forum, c'est parce que c'est une bêta privée.
Pas de spam ni autre. Juste parce que le programme sera en GPL, mais que pour l'instant, le code n'est pas public.
Sinon, je viens de tester le lien, il marche bien ...
Edit : Vu les logs de ScanChannelBDA_UK, tu n'est pas obligé de cocher Analyser les fréq. non verrouillées mais il faut bien cocher Ne pas se fier à la qualité. Quelques secondes de gagner...
rvs
Messagepar Maurice83300 » 27 Sep 2012 18:43
Schell a écrit: Autrement dit, il voit les bouquets mais c'est marqué :
# scan timed out
Oui, il voit les canaux 49, 51, 56, 58, 60 et 62
J'ignore si ce sont les bons
Mais il ne reçoit aucune données, d'ou la qualité à 0.
Ces canaux sont reçus avec une force à 79 alors que l'abscence de signal donne une force à 94.
J'ignore à quoi correspond pour ta carte une force à 79 mais je me serais davantage attendu à trouver une valeur négative (ou inférieure à 20) en présence d'un signal (eu égard au 94 en absence de signal).
Es-tu certain du bon fonctionnement de ta prise, et de celui du câble qui la relie à ta clé ?
Il faudrait la tester avec ta BOX par exemple.
Maurice83300
Messagepar Schell » 27 Sep 2012 18:46
rvs a écrit:Si on demande un enregistrement sur le forum, c'est parce que c'est une bêta privée.
Le lien que tu as donné me donne :
Vous n’êtes pas autorisé à lire ce forum.
pourtant je suis bien inscrit.
Schell
Messagepar rvs » 27 Sep 2012 19:08
Envois un MP à Ronaldo1 http://www.tvnt.net/forum/membre4214.html, il est connu aussi du coté de notre forum :wink:
rvs
Messagepar Schell » 27 Sep 2012 19:45
# scan timed out
C'est bon j'ai trouvé !
En fait en sortie de la prise NUMERICABLE j'avais un té, qui ne génait pas la réception de la BOX et de la télé.
En branchant directement sur la clé, il trouve les chaines.
Merci beaucoup pour votre aide.
Savez-vous comment remplacer mon té et brancher la prise sur la box + la ce
Schell
Messagepar Anonymous » 27 Sep 2012 22:46
Comme maintes fois répété ici :
PROSCRIRE LES T
METTRE DES REPARTITEURS
Messagepar Maurice83300 » 28 Sep 2012 07:10
Schell a écrit:En branchant directement sur la clé, il trouve les chaines.
Que dit scanchannel dans ces conditions ?
Quelle est la longueur et la qualité de ton câble vers ta clé?
Si ta BOX est capable d'afficher la force du signal, quelle est cette force lorsqu'elle est branchée seule?
Il faut remplacer le T par un répartiteur ou par un ampli à deux sorties si le signal devient trop faible.
Maurice83300
Messagepar Franck Morin » 28 Sep 2012 08:14
j'ai personnellement une clé Pinacle PCTV (non hybrid) et je peux te dire que c'est de la m... comparé à d'autres genre terratec.
pas étonnant que ta TV décode et pas cette clé alors que le signal est a priori réparti équitablement entre les deux parties du T.
mais c'est certain, mieux vaut utiliser un répartiteur faible pertes. Tu te fais de plus ton propre câble (voir la rubrique appropriée du forum)
