# Where can I get the source code to contribute to the Dr. DivX 2.0 OSS project?
The source code can be found on the Dr. DivX project page on Source Forge
Version 2.0.0 beta 3
* What's new
o New setting to allow removing the job working folder in case of job failure (always done on successful jobs)
o Allow AC-3 audio passthrough (there is a bug found, so its only working in wizard mode right now)
o Display the most DirectShow filters most likely to be used (AC3, DTS, AAC) in the preferences
o Use the Logs dir to store saffron.log and per-job logs
o New option to start jobs on startup (Batch & Expert mode) (off by default)
o Swedish translation by Glenn
o French translation by Oliver
* What's Fixed
o Output files with a Unicode name were truncated
o Job reordering works again
o Set correct track information in strn chunk of divx file
o Fix some DV samples where the crop detection was not working
o Audio delay for AC3 tracks is compensated for correctly for streams that have negative delay.
virtualdubmod quant à lui veut bien, mais en fast recompress je suis à 8 % du traitement et le fichier avi fait 6go...
