[Topic unique] Terratec Cinergy 2400i DT
Re: [Topic unique] Terratec Cinergy 2400i DT
Messagepar Maurice83300 » 28 Juil 2009 21:21
Le premier tuner, effectivement, ne fonctionne pas.
Mais j'aurais préféré cependant le log des deux tuners en option 1
Ils peuvent faire apparaitre d'autres renseignements (scan canal vide, offsets, etc ).
Maurice83300
Messagepar sebor » 28 Juil 2009 21:47
voilà le log pour l'option 1.
Je pense que le ,tuner 1 est bien mort...
ScanChannelsBDA starting
Tue Jul 28 22:30:48 2009
Build - v2.7.0.0
Checking for new BDA DVB-T Cards
Tuner - Cinergy 2400i DT Tuner 1
@device:pnp:\\?\ngene#ven_18c3&dev_0720&subsys_1167153b&rev_00&tuner#7&1b78fb52&0&2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{2745a7ad-e8ca-11d8-a988-004030004d56}
Finding Demod and Capture filters
Trying - Cinergy 2400i DT Capture 1
@device:pnp:\\?\ngene#ven_18c3&dev_0720&subsys_1167153b&rev_00&capture#7&1b78fb52&0&4#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{2745a796-e8ca-11d8-a988-004030005452}
SUCCESS
Checking for Capture filter
Trying - Cinergy 2400i DT Capture 2
@device:pnp:\\?\ngene#ven_18c3&dev_0720&subsys_1167153b&rev_00&capture#7&1b78fb52&0&4#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{2745a797-e8ca-11d8-a988-004030005452}
Trying - Détrameur décalage BDA
@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{03884cb6-e89a-4deb-b69e-8dc621686e6a}&global
Trying - Filtre BDA MPE
@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{8e60217d-a2ee-47f8-b0c5-0f44c55f66dc}&global
Finished Finding Demod and Capture filters
Capture - Cinergy 2400i DT Capture 1
Tuner - Cinergy 2400i DT Tuner 2
@device:pnp:\\?\ngene#ven_18c3&dev_0720&subsys_1167153b&rev_00&tuner#7&1b78fb52&0&2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{2745a7ae-e8ca-11d8-a988-004030004d56}
SUCCESS
Capture - Cinergy 2400i DT Capture 2
Finished Checking for new BDA DVB-T Cards
2 BDA devices found.
using Cinergy 2400i DT Tuner 1
# 306000kHz
# signal locked = N present = N strength = 100000 quality = 0
# trying +166kHz
# trying -166kHz
# Nothing found on 306000kHz
# 462000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 462000kHz
# 474000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 474000kHz
# 482000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 482000kHz
# 490000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 490000kHz
# 498000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 498000kHz
# 506000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 506000kHz
# 514000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 514000kHz
# 522000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 522000kHz
# 530000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 530000kHz
# 538000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 538000kHz
# 546000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 546000kHz
# 554000kHz
# trying +166kHz
# trying -166kHz
# Nothing found on 554000kHz
# 562000kHz
Tue Jul 28 22:31:48 2009
Build - v2.7.0.0
SUCCESS
SUCCESS
# trying +166kHz
using Cinergy 2400i DT Tuner 2
Frequency (Scanned) = 610000kHz
Frequency (Actual) = 0kHz
Network Name = F
Channel Name LCN SID Vid Aud PMT
Direct 8 , 8, 513, 160, 80, 1280 # Teletext=32
BFM TV , 15, 515, 162, 88, 1282 #
i>TELE , 16, 516, # trying +166kHz
163, 92, 1283 #
Virgin 17 , 17, 517, 164, 96, 1284 # Teletext=44
Gulli , 18, 518, 165, 100, 1285 # Teletext=48
France 4 , 14, 519, 166, 104, 1286 #
# Signal Strength = 10800
# Signal Quality = 100%
Frequency (Scanned) = 626000kHz
Network Name = F
# Nothing found on 778000kHz
# 802000kHz
# Signal Strength = 9600
Summary of frequencies
Please note that strength may not be an accurate figure. The actual meaning
of strength depends upon the manufacturer of your device.
Frequency (Scanned) = 674000kHz
Network Name = F
France 2 , 2, 257, 120, 130, 110 #
France 5 , 5, 260, 320, 330, 310 #
ARTE , 7, 261, 520, 530, 510 #
ARTE , , 261, 520, 531, 510 #
LCP , 13, 262, 620, 630, 610 #
France 3 , 3, 293, 220, 230, 210 #
ORLEANS TV , 25, 373, 720, 730, 710 #
# Signal Strength = 8300
# 690000kHz
# signal locked = Y present = Y strength = 7500 quality = 100
Frequency (Scanned) = 690000kHz
Network Name = F
M6 , 6, 1025, 120, 130, 110 #
M6 , , 1025, 120, 131, 110 #
W9 , 9, 1026, 220, 230, 210 #
W9 , , 1026, 220, 231, 210 #
NT1 , 11, 1027, 320, 330, 310 # Teletext=340
PARIS PREMIERE , 31, 1028, 0, 430, 410 #
PARIS PREMIERE , , 1028, 0, 431, 410 #
ARTE HD , 57, 1031, 0, 730, 710 #
ARTE HD , , 1031, 0, 731, 710 #
# Signal Strength = 7500
Frequency=610000kHz Strength=10800 Quality=100%
Frequency=626000kHz Strength=9600 Quality=100%
Frequency=674000kHz Strength=8300 Quality=100%
Frequency=690000kHz Strength=7500 Quality=100%
sebor
Messagepar Maurice83300 » 28 Juil 2009 22:40
Pourtant, lors du premier test, il avait semblé vouloir accrocher, mais tu avais donné des mauvais paramètres (la largeur de bande doit être à 8 Mhz, tu sembles avoir mis 46 Mhz):
# locking 674000, 46
# signal locked = N present = N strength = 9350 quality = 20
# signal locked = N present = Y strength = 9350 quality = 20
# signal locked = N present = Y strength = 100000 quality = 20
Dans ton dernier test, le fichier est incomplet, il manque, pour le tuner 1, toutes les fréquences des multiplex que tu devrais recevoir!
Essaies de faire "Ajouter des fichiers joints" au lieu de faire des copier/coller.
Maurice83300
Messagepar sebor » 29 Juil 2009 07:04
bonjour,
voilà,
j'ai refait un test avec une bandwidth de 8 comme tu me l'avais dit.
J'ai réussi à compresser le fichier qui englobe les rapports d'hier et de ce matin.
Manifestement , mon tuner 2 vient aussi de lacher ce matin.... :evil:
Il semblerait en effet qu'un signal soit capté de temps en temsp mais ils n'arrivent pas à locker dessus. De plus, je le trouve bien faible en qualité ( 20 ).
J'attends ton analyse.
en te remerciant,
cdt,
sebor
Messagepar Maurice83300 » 29 Juil 2009 07:51
Je ne comprends rien à ton fichier log. Je ne sais pas si tu l'as édité ou ce que tu as fais?
- Effaces ton fichier "ScanChannelsBDA.log".
- Relances "ScanChannelsBDA".
- Choisis le premier tuner.
- Choisis l'option "1".
- Laisses le test se dérouler seul jusqu'à la fin.
- Option "10" pour sortir.
- Renommes "ScanChannelsBDA.log" en "ScanChannelsBDA_T1.log".
- Choisis le deuxième tuner.
- Renommes "ScanChannelsBDA.log" en "ScanChannelsBDA_T2.log".
- Compresses "ScanChannelsBDA_T1.log" et "ScanChannelsBDA_T2.log" pour les envoyer.
Maurice83300
Messagepar sebor » 29 Juil 2009 08:40
je referai la manip que tu me décris ce soir.
le fichier sera compressé car je ne peux pas joindre d'extension LOG en temps que pièce jointe dans les posts ( le forum ne m'autorise pas )
En te remerciant,
S.
sebor
Messagepar Maurice83300 » 29 Juil 2009 09:27
sebor a écrit:le fichier sera compressé car je ne peux pas joindre d'extension LOG.
Pas de problème pour moi, mais demandes à WinRAR de les compresser en .ZIP que tout le monde peut décompresser.
Attention, je m'absente bientôt.
Maurice83300
Messagepar sebor » 29 Juil 2009 10:53
pour info et pour ceux que ça intéressent : Materiel.net a admis qu'ils ont eu une "légère" hausse sur les retours de la cinergy 2400 iDt et qu'ils surveillent de "près", mais trop tôt pour parler de série défectueuse.
a surveiller aussi de notre coté pour les malheureux :roll: comme moi et de ne pas lâcher l'affaire!
S.
sebor
Messagepar Maurice83300 » 29 Juil 2009 11:08
sebor a écrit:Materiel.net a admis qu'ils ont eu une "légère" hausse sur les retours de la cinergy 2400 iDt .
Comment être sur que tu n'es pas, à toi seul, le principal (pour ne pas dire le seul) responsable de cette "légère hausse" ?
Maurice83300
Messagepar sebor » 29 Juil 2009 18:25
effectivement je n'avais pas songé à ça....
cela dit, après avoir fait les comptes sur les différents forums, dont celui ci, j'estime qu'on est au moins 4 ou 5 à contribuer à cette hausse de statistique...
je vais m'occuper dans la soirée des log que tu m'as demandé
S.
sebor
